64 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Spot Elevation on linked file
Wed, Mar 17, 2010 at 10:52:04 AM | Spot Elevation on linked file
bert
Hello!
This may be an easy one... I'm trying to show the difference in levels in my project, but noticed I can't place spot elevations on floors in a linked structural file, whereas I still can on architectural elements. Is there a way to get around this?
Thanks!
Great Revit karma will come to you for answering my many questions.
using RAC-2013
Blog: Revit Templateer
Wed, Mar 17, 2010 at 11:07:27 AM | Spot Elevation on linked file
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
open the linked file separately, I am assuming that you are linking a revit structural file.
Wed, Mar 17, 2010 at 7:46:23 PM | Spot Elevation on linked file
bert
I'm not sure how that would make a difference; any annotations placed in the linked file won't show up in the architectural file. Could you elaborate a bit more?
using RAC-2013
Thu, Mar 18, 2010 at 11:12:53 AM | Spot Elevation on linked file
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I thought you were interested in the particular spot elevation, just write in text.
Thu, Mar 18, 2010 at 11:21:51 AM | Spot Elevation on linked file
bert
I'm not really interested in work-arounds, I mean, I rather not place any dumb tags/text. I guess I'm just surprised by it not working.
using RAC-2013
Fri, Mar 19, 2010 at 11:55:30 AM | Spot Elevation on linked file
bert
I found a solution...
Spot elevations don't work on the top face of the linked slab, but they do find the edge of the slab...
using RAC-2013
Fri, Mar 19, 2010 at 12:15:07 PM | Spot Elevation on linked file
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Thanks for the info.
Tue, Aug 14, 2018 at 8:41:53 AM | Spot Elevation on linked file
Kuspat
That's not quite true. Please see attached screenshot were I was able to spot elevation on a linked revit model.
However after a while this feature stopped working in our file and right now I can't even spot the elevation on the edges of the linked file.
I am still looking for the solution.
Has anyone found a solution. Is there any setting driving the behaviour of the linked file?
Tue, Aug 14, 2018 at 9:56:50 AM | Spot Elevation on linked file
Look at the following image.
Tue, Aug 14, 2018 at 9:58:36 AM | Spot Elevation on linked file
And this image.
Thu, Aug 16, 2018 at 5:05:52 AM | Spot Elevation on linked file
Kuspat
It is not the case of enable the link on the selection tool. Already tried that.
Spot elevation tools works perfectly if I create a new floor plan of the same level. At the same time on the current drawing it is not working.
I just opened a case with Autodesk on this issue. Will post a solution if Autodesk resolves it.
Fri, Aug 17, 2018 at 10:10:04 AM | Spot Elevation on linked file
Kuspat
The problem was related to Visibility/ graphics settings specifically Floors category ( Common edges, Hidden lines, Slab edges subcategories were unticked). At least it seems that it was the problem because the elements I was placing spot elevation tags was a structural foundation category so it is a bit ackward. These are tottaly different categories. Nonetheless all spot elevation tagsdescribing the linked model automatically appered again.
I can't confirm wheter it was really the problem or it is a software malfunction.
Mon, Apr 8, 2019 at 5:15:37 AM | Spot Elevation on linked file
#13
intexxx
I know this thread is old, but the solution to this problem is to simply just turn on the visibility of <Room Separation> or <Space Separation> under LINE category.
CHEERS
Spot Elevation vs. Level elevation
Wed, Feb 14, 2018 at 6:13:21 PM
Change spot elevation dimensions 0.00 coordinate
Sat, Feb 4, 2012 at 10:56:06 AM
Target size of Spot Elevation (Revit Architecture 2008)
Wed, Aug 6, 2008 at 9:43:57 AM
Invert Elevation Vs. Spot Elevation
Mon, Apr 20, 2015 at 2:09:12 PM
Spot Elevation without Target
Fri, Mar 20, 2009 at 4:57:56 PM
Page generation time: 1.9947
