69 Users Online (67 Members):
Forums >> Revit Building >> Technical Support >> Single hung window with unequal sash - Revit 2009
Can anyone help me with a parametric window? I need a single hung with the lower sash being 1/3 the total height and the upper fixed sash being 2/3 the total height. The height parameter will only allow me to have the sash be equal/
----------------------------------- Jeff Frame AIA |
Just a question: Did you search here in the download section or in www.arcat.com or in www.seek.autodesk.com for that window?
I found a window in Arcat worked great. Also, if you take off the equal dimensions and add it as an "instance parameter" you have complete control over the placement of the sash.
Single hung Eyebrow's? |
Mon, Dec 3, 2007 at 4:22:54 PM
Building Families - Window (Single Hung Sector Top) |
Fri, Dec 7, 2007 at 12:19:44 PM
How to make double or tripple Andersen double-hung windows |
Sun, Jan 11, 2009 at 12:38:51 PM
easiest way to create a window sash |
Sat, Feb 4, 2006 at 4:04:03 AM
Andersen double hung windows |
Sun, Jan 18, 2009 at 4:45:24 PM
Members: | 2022358 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
