69 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Struggling with Angled Parameters and getting things to move together.
Tue, Mar 16, 2010 at 9:30:19 AM | Struggling with Angled Parameters and getting things to move together.
Nathan1
I am new at making complex (or at least complex to me) revit families.  I have two conveyors I need to make for a processing plant.  We use revit arch and mep 2010.  The gooseneck conveyor needs to be able to be height and width adjustable, but the angle is fixed at 55 degrees.  I need to have 'fins' perpendicular to the belt that keep the product from falling down the conveyor.
Questions:
How do I get the fins at a fixed distance of 8" to add or subtract as the conveyor gets taller.
How do I get the top rollers and drip pans to move with the top of the conveyor
Regarding the second conveyor I have been able to adjust for width and lenght, but do not know how to make it adjust of the angle of incline.
 Any help would be appreciated.
 Thanks,
Nathan
Tue, Mar 16, 2010 at 9:34:24 AM | Struggling with Angled Parameters and getting things to move together.
3.5 Stars: 396 Votes
To learn how to build families, there is a lot of information at this location.  In particular, look at the family guides - it will help you especially with angles in families.
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=11091739
Tue, Mar 16, 2010 at 12:34:38 PM | Struggling with Angled Parameters and getting things to move together.
Nathan1
The goose neck attachment.
Tue, Mar 16, 2010 at 12:38:28 PM | Struggling with Angled Parameters and getting things to move together.
Nathan1
Thanks, I have downloaded the family pdf and will try to work through it.
Wed, Mar 17, 2010 at 5:15:24 AM | Struggling with Angled Parameters and getting things to move together.
4 Stars: 201 Votes
Here you have a simple video about "Angle a door": http://www.screencast.com/users/hrbarchitect/folders/Revit%20Clinic%20Videos/media/51ce9fef-2f76-437a-8e9c-b3e1c479dfd5
I hope this help you too...
Wed, Mar 17, 2010 at 9:56:27 AM | Struggling with Angled Parameters and getting things to move together.
Nathan1
Thank you...the video helps a lot.  They say a picture is worth a thousand words...video is worth a million.  I should now be able to get this to work.  I will give it a whirl.
Making Angled or canted walls
Tue, Jun 3, 2008 at 2:10:07 PM
angled corner joint - how to lock angled corners
Thu, Jul 18, 2013 at 5:10:11 AM
11
Angled Curtain Walls - Not Sloping Glazing
Wed, Apr 22, 2009 at 3:20:31 AM
angled parapet caps not connecting
Fri, Jan 16, 2009 at 3:47:52 PM
Struggling with Stairs
Sat, Jul 15, 2017 at 5:41:35 AM
Page generation time: 0.5472
