59 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Rendering at 1d 10 hrs and only 63% (8"x10" 150 dpi Best)
Tue, Mar 16, 2010 at 12:13:00 AM | Rendering at 1d 10 hrs and only 63% (8"x10" 150 dpi Best)
SirLyons
SirLyons Avatar
I am currently running a rendering on best quality and its made it to 50% in about 9 hours and now it has been at 63 percent for the past 7 hours.  I am pretty sure it is still rendering because as few more of the squares have finished.  Also the rendering is 8"x10" 150dpi set on Best.  I have attached a copy of a lower quality rendering so you can see what I am working with.
 My computer specs are as follows:
6GB Ram  Intel Xeon 2.33 Ghz Processore and a 512 MB 9600 GT Video Card with a 320 GB harddrive that is not even close to being full.
So, I don't think that is the problem.  I had the computer built by Xi Computers and it is cooled very well.
If you have any ideas why it might be taking so long please let me know.
Thanks,
-Michael
Fay Jones School of Architecture | University of Arkansas | Design Build | 4th Year
Tue, Mar 16, 2010 at 9:17:11 AM | Rendering at 1d 10 hrs and only 63% (8"x10" 150 dpi Best)
4 Stars: 203 Votes
Well, interior renders in Revit is a pain in the butt, and it's worse if you have many lights, reflections, curtain walls... I hope, in 2011 version, they correct/Improve this issue.
Tue, Mar 16, 2010 at 12:39:45 PM | Rendering at 1d 10 hrs and only 63% (8"x10" 150 dpi Best)
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
What people don't take into consideration for rendering are the materials.
Materials can kill a rendering as bad or worse than complex lighting.
The more complex the material the worse off Revit will be.
  • Bumb maps
  • High Gloss
  • Perforations or Cut-outs
All these things will really impact performance. Also, you have daylight portals which increase time significantly.
Other items to consider:
What is your opertating system? 64bit?
Is your PC using a dual processor?
What is your page file set to?
You could try setting the priority a little higher for Revit...BUT DO NOT SET IT TO REAL TIME!!!! It will lock your computer by assigning all resources to REvit...your mouse will not even work.
I would do this ONLY as a last resort....ONLY!
Edited on: Tue, Mar 16, 2010 at 12:41:17 PM
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Rendering Help
Thu, Jan 13, 2011 at 4:06:37 PM
Revit 2011 renders on 75DPI but not on 150 DPI
Wed, Nov 28, 2012 at 5:48:09 PM
Rendering wont do second cycle - revit arch 2010
Mon, Nov 30, 2009 at 2:14:02 PM
Distributed Rendering
Mon, Aug 17, 2009 at 2:02:38 PM
large format rendering
Thu, Oct 22, 2009 at 8:44:34 AM
Page generation time: 0.8968
