70 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Unwanted Color in Plan View
Mon, Mar 15, 2010 at 6:03:35 PM | Unwanted Color in Plan View
ecriswell7
See the attached image but I have tried everything I know to do with getting this magenta line changed to black.  I have gone through an tried to over ride the wall element and it will not change.  Any thoughts on whats going on and how to change it?  These are the only line in the entire plan that are colored.  Thanks for any help!
Mon, Mar 15, 2010 at 9:07:49 PM | Unwanted Color in Plan View
coalstone
2.5 Stars: 3 Votes
That is the strangest thing that I have ever seen. Usually purple means that you selected it with your cursor. Try clicking on something else. If that doesn't doesn't work I have no clue what's wrong.
Tue, Mar 16, 2010 at 9:31:55 AM | Unwanted Color in Plan View
Dafpfy
3.5 Stars: 11 Votes
if all else fails ,
use linework tool?
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Tue, Mar 16, 2010 at 9:39:23 AM | Unwanted Color in Plan View
Color is a VG issue.  Look at your object styles and if you have linked files, turn on show categories from all disciplines.
Tue, Mar 16, 2010 at 10:41:51 AM | Unwanted Color in Plan View
TomDorner
4.5 Stars: 25 Votes
Looks like a room seperation line or area boundry line to me as both by default are purple.
If not needed you can simply delete, or go to VG and turn either one or both off.
Tom
www.reviteer.com   http://twitter.com/Reviteer
"System Color Schemes" not regular color schemes in Elevation or Section views
Mon, Mar 22, 2010 at 6:00:00 PM
Window fill color in plan view
Tue, Jan 22, 2013 at 4:30:38 PM
change shade color in views
Tue, May 15, 2007 at 11:40:20 AM
Coloring elements - plan view
Sun, May 28, 2006 at 2:13:39 AM
COLOR SCHEME IN SITE PLAN
Fri, May 29, 2009 at 8:51:17 AM
Page generation time: 1.6204
