81 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> sloped slab edge
Mon, Mar 15, 2010 at 5:05:54 PM | sloped slab edge
NIC1352
Why am I finding it impossible to add a slab edge to the slopped side of a sloped slab?
Mon, Mar 22, 2010 at 7:16:27 AM | sloped slab edge
shaverjeff
This is a know limitation of the slab edge tool.
Slab edges can't be applied to the edge of a sloped slab using the "slab edge" tool.  You can however place the slab edge on a flat slab, then slope the slab and the edge will follow suit.  Note that the slab edge will not follow sloping slabs generated using the "modify subelements" tool. You will need to use a slope arrow or defining edge slope method.
Slab Edges on Sloped Floors
Wed, Aug 12, 2009 at 12:37:29 PM
"Could not create Slab Edge"
Tue, Feb 17, 2009 at 1:40:43 PM
RC upstand on the edge of an RC slab
Thu, Jul 14, 2011 at 11:04:57 AM
Revit 2010 Slab Edge Trouble
Mon, Feb 15, 2010 at 8:54:40 AM
Need help creating a sloped slab with Radius Edge
Tue, May 2, 2006 at 5:23:53 PM
Page generation time: 0.2919
