Forums >> Revit Building >> Technical Support >> Disappearing Surface Pattern
I have a surface pattern on a roof paver tile so that I see the 18"x18" tiles. However, I want to see through the pavers so I can highlight the sloping roof below. I added a filter that makes my pavers halftone and transparent and then another filter to bold and hidden line my sloping roof. It looks exacetly the way on I want on my screen. However, when I print it, some of the surface patterns disapear randomly. I should mention that I have many different paver floors because of many different colors and rotations of the tiles. 98% of them show correctly on the print, but it should print 100% of them. Is there something I should check?
Revit Architecture 2011 |
Are you printing raster because of shading? If so, that may account for your problem. Halftones seem to be a problem on lines other than normal - we see differences on curves vs normal lines. The problem is because of the pixels... Did you try printing to a pdf first then printing that?
We always print with vector. Which is where I'm experiencing the problem. If I print it in raster I don't have the problem, but I'll only print that one sheet in raster. I tried print on a laser printer, full size plotter and PDF and all had the same result when print as vector. Thanks for your input.
20 Posts No Rating |
I'm having the same problem with my rcp drawing. The surface hatch is displaying on all ceilings but two. All the properties are the same. Any clues? Is this just a glitch. Please see attached file. Thanks in advance
99.999% sure it is a user issue. Possibilities - I know you think the properties are the same but we have seen far too many of these: - Is the ceiling really there (the tag is to this ceiling - not adjacent)
- Ceilng is out of view.
- Over-ride graphics in view by element
- Ceiling is not the same....
- You are playing around with phases.
Thanks for the response but:
- Is the ceiling really there (the tag is to this ceiling - not adjacent)-Yes ceiling is there
- Ceilng is out of view.- no ceiling is not out of view
- Over-ride graphics in view by element- no graphics over-ride
- Ceiling is not the same....- It is the same
- You are playing around with phases.-We are not using phases in this project.
Anyother ideas? Thanks
Are your surface patterns 'Drafting' or 'Model'?
Drafting- they pattern is connected to the ceiling, in the ceiling properties. Therefore it doesn't make sense why all the other plank ceilings show up except these two. I ended up having to add a filled region to make it show up. Still love input on what might be wrong. Thanks
Here is a test for you - create a new ceiling plan. Don't copy the existing one. Justr uncheck the do not duplicate box and create the plan from the Create / Plan Views / NEW RCP and set the scale to a large scale. Then if the ceiling does't come in, match ceiling properties good to bad or vice versa and see what happens.
Edited on: Mon, Dec 6, 2010 at 3:00:18 PM
