Forums >> Revit Building >> Technical Support >> Removing multiple curtain wall grid segments
17 Posts No Rating |
I am trying to remove a large number of grid segments but don't know how to do it quickly and efficiently as i keep doing each one separately. As there is a very high amount of segments, i'm hoping there is a quicker way. Any help would be appreciated revit 09 +10
There isn't a quickly way to do that, just pick and "Add/remove...".... Sorry mate...
Certainly they need to change that in the new revit - this is just painful doing it. Spent the last 2 n half hours removing segments and about half way through. Watching 6 nations while doing it now. Ha ha
69 Posts No Rating |
I certainly also would like a way of deleting multiple curtain wall grid segments. Mine are usually not many Have you tried to go the other way; remove all (change the curtain wall family) and then create the once you want ? I guess it depends on waht is the quickest
0 Posts No Rating |
I had the same issue but I found a solution to easily delete single segments of a curtian grid system.
1. Go to Architecture Tab
2. Select Curtian Grid
3. Modify/Place curtian grid will pop up.
4. Select the cut tool, that splits in two.
5. If you want to cut Horizontal segment, cut at a vertical grid line.
6. Then it will show segments as its own piece.
7. Select segment and press delete. (I prefer delete on keyboard for best efficiency)
Hope this helps!
Curtain Grid Removing Segments |
Mon, Jul 2, 2007 at 1:05:13 PM
Removing Segments from a wall sweep |
Mon, Jan 16, 2012 at 11:25:13 AM
Revit 2013 Curtain Wall Variable Grid Spacing |
Thu, Jul 18, 2013 at 2:10:55 AM
removing grid lines from curtain |
Thu, Oct 11, 2012 at 11:59:28 AM
Curtain Wall Grid Angle |
Tue, Feb 15, 2011 at 2:42:33 PM
Members: | 2116569 | Objects: | 23196 | Forum Posts: | 152303 | Job Listings: | 3 |
