Forums >> Revit Building >> Technical Support >> adjustable profile family
1 Posts No Rating |
Is it possible to create an instance parameter within a profile family that will allow the profile to adjust without creating a new type for every size you need? I am thinking specifically of a coping profile that will adjust according to the thickness of the wall it is assigned to. I have created reference planes, locked dimensions and assigned a parameter within the profile family so that it is adjusting properly. But is there a way to assign that parameter to a piece of information within my project (Total thickness of wall) so that it will adjust according to the wall's properties without creating a new profile type for each wall thickness? I believe windows and doors accomplish this by inserting a generic wall into the family, but I can't insert a generic wall into a profile family...or can I?
36 Posts No Rating |
I don't think that this is possible at this time... I have tried to do the exact same thing in the past, but I just wind up having to make many different types within the profile family to accomodate the varried widths that I need. Hopefully someone wiser will prove me wrong with some clever work-around. (I tried changing the category of a window family, but it won't let me make it a profile. I did like your idea though)
9 Posts No Rating |
would using a formula in the parameter work?? ie: "coping size = width/2" or whatever you need..... just a thought, I'm fairly new at this.
The answer is no ... at least not yet ... maybe this is something that will change. As you found out, you have to create a new type and then assign that type.
It is not possible with profiles, because the instance properties of a profile are lost once the profile is loaded into anotherfamily, only the type properties remain; so a profile is supposed to be used with types.
However, it is possible in other ways, not with profiles, though. You could create a wall based family for the coping, whose width is aligned and locked to the faces of the host wall.
Planta1 Revit Online Consulting | info@planta1.com |
alf - While you are correct, the true coping tool works so much better and is really the best choice. Families will not turn corners or automatically join at corners.
Hmm.. actually, some families with parametric sections can turn corners. Please look at this video about a curb:
http://www.youtube.com/watch?v=GsJNn0pi994
While this is definitly interesting..... I am smiling right now .... I think I will stick to creating a profile type for my copings. As a matter of fact, my coping prfile already has multiple types in it of the most common widths we use.
Nice
Haha... OK, but they can turn corners...
What is the "coping tool" that you mention in post # 6 above?
My mistake ... I should have said "Wall sweep/cornice" I should know better!
