71 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Overlapping curtain panel wanted
Fri, Mar 12, 2010 at 1:48:08 PM | Overlapping curtain panel wanted
Altruant
I am trying to allow a curtain wall panel to overlap but it is not allowing it and constantly pressing itself within the boundaries.
Is there anyway to change this so it is not constrained.
The photo belows shows the brickwork desired followed by what happened when placed into panels.
 http://www.brick.org.uk/_media/_images/_awards//__standard/10311BW_SAHRC.jpg
Fri, Mar 12, 2010 at 1:55:12 PM | Overlapping curtain panel wanted
4 Stars: 203 Votes
I don't know how did you create that curtain panel but did you try to change the "Layout" of that curtain wall and check if that solve the problem?
Fri, Mar 12, 2010 at 5:34:51 PM | Overlapping curtain panel wanted
Altruant
Hey did a few adjustments myself and tried fiddling around with those the type settings and it worked.
 I am now trying to find out a way to punch holes in it for the windows as this is actually the facade. I have tried editing profile but it ends up making the panels very patchy. I will try again tomorrow.
 Maybe face based panels would work with voids? I have yet to try it. But if you could suggest anything else then that would greatly appreciated. Smile
Sat, Mar 13, 2010 at 2:44:32 AM | Overlapping curtain panel wanted
Altruant
Tried face based panels and did not work.
 Any idea how to make the curtain wall so it literally blows holes where i want taking the panel along with it?
EDIT: Removed segments and hid panels that were not needed in view for renderings. Will need to adjust the windows a bit on my original design but i think it should look excellent in the end.
Edited on: Sat, Mar 13, 2010 at 5:37:21 AM
Wood Screen - Curtain Panel
Sat, Jan 10, 2015 at 1:44:00 AM
Curtain system panel problem
Tue, Jul 10, 2007 at 10:08:07 AM
curtain panel offset
Mon, Sep 1, 2014 at 4:30:14 PM
Nesting curtain panel family
Mon, Mar 25, 2013 at 7:56:10 AM
Curtain Wall Panel to Curtain Wall Door
Page generation time: 0.5304
