148 Users Online (147 Members):
Forums >> Revit Building >> Technical Support >> Room Bounding Families
3 Posts No Rating |
I am creating a family (An elevator) and need the cab to be room bounding so that I can include it as a room. As it is right now, I cannot figure out how to do so. I end up adding room separation lines to create the room once the family is loaded into my project. Any ideas how to do this, or how to create families that include room bounding objects, such as walls?
Rom bounding is a system property and I don't know of any way of adding it to a family.
WWhub is correct. Room sep lines are only available inside a Revit project. A workaround is to create a seperate Revit project, load your elevator family, add the room sep lines, group everything and save out the group as a new Revit project. Then when you need to use the elevator,in a new project you load and place the group which contains the elevator and the room sep lines.
3 Posts No Rating |
Thanks. I will try the group idea.
room bounding problem |
Fri, Jul 28, 2017 at 4:03:50 AM
13
Ceiling not bounding room |
Wed, Oct 6, 2010 at 4:01:35 PM
Room Bounding - Room area changes, then changes back for no reason! |
Wed, Apr 28, 2010 at 6:22:40 PM
BIG curtain wall room bounding problem!! |
Mon, Dec 14, 2009 at 9:31:31 AM
room bounding parameter in wall |
Fri, Jun 27, 2008 at 10:17:07 AM
Members: | 2030717 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
