82 Users Online (81 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Clay tile roof
Thu, Mar 11, 2010 at 5:16:00 PM | Clay tile roof
Sissela
How do I draw a clay tile roof. I am using Revit 2010.
Fri, Mar 12, 2010 at 3:18:01 AM | Clay tile roof
Kardiff
5 Stars: 3 Votes
Make a new matierial and call it 'Clay tiles'
Under Properties > Render Appearence > Choose an Image file of Clay tiles
Under bump > use the same file for now, and set it to something around 0.2
Now when you use that material it'll render like the image you used
- Just trying to help out while I wait in the office for my renders to complete
www.danrossiter.co.uk
Fri, Mar 12, 2010 at 5:29:17 AM | Clay tile roof
4 Stars: 201 Votes
Like the images i post? You can do that in several ways, use only Texture like Kardiff told you or you can use also the "Sloped Glazing" system in the roof to create that in 3D BUT that gonna increase the file size, all depend what you really need/want and the capacity of your machine...
Fri, Mar 12, 2010 at 7:07:45 AM | Clay tile roof
EugenioFV
Typhoon, that looks crazy good.
Fri, Mar 12, 2010 at 1:04:37 PM | Clay tile roof
4 Stars: 201 Votes
Do you think so?  Thanks i like too....
Sat, Mar 13, 2010 at 1:06:37 PM | Clay tile roof
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Frowning.....................
Sun, Mar 14, 2010 at 2:22:41 PM | Clay tile roof
hisdirt
5 Stars: 5 Votes
Hi Typhoon, that clay tile system is really good!
 Could you give us some insight to how you achieved this, with the fascias + corners etc? The dormers on the 3rd image look great!
Mon, Mar 15, 2010 at 5:50:16 AM | Clay tile roof
4 Stars: 201 Votes
Hisdirt, like i said before we can do that in several ways but in those roofs i simple use a Texture for the main roof, the fascias and corners are parametric families, you can found them here in the download section....
Sun, Feb 19, 2012 at 1:56:00 AM | Clay tile roof
kiddserv
Typhoon: sorry to bring about an old thread, but i really need help in creating clay/span tiles for rendering in my model and i found your way to be time efficient enough with satisfactory outputs.. where do I get your corner & fascia files? what to search in Download Section and lastly, can you explain the process of how to use them? im kinda new to Revit so i need to catch up fast.. help would be greatly appreciated.. thanks!
Sun, Feb 19, 2012 at 6:40:05 AM | Clay tile roof
4 Stars: 201 Votes
Follow this thread: http://www.revitcity.com/forums.php?action=viewthread&thread_id=22937#t87417
Sun, Feb 19, 2012 at 11:05:09 AM | Clay tile roof
#11
kiddserv
ok i will try my luck in that thread.. thanks Typhoon.
Fri, Oct 3, 2014 at 4:42:22 PM | awesome
#12
zainababbas
Typhoon..
really liked your work...do u upload your portfolio somewhere? coz id really like to see your work....sorry for simply putting up the comment... Smile
Clay Roof Tile Pattern
Wed, Mar 3, 2004 at 10:28:13 PM
Clay tile roof family
Tue, May 9, 2006 at 1:26:35 PM
Clay Tile Roof Accurender patern
Sun, Sep 30, 2007 at 3:17:33 PM
Clay Roof Tile -Fill Pattern issue
Sat, Aug 6, 2005 at 5:17:39 PM
Roof Tile
Sat, May 15, 2010 at 2:50:33 AM
Page generation time: 1.2590
