130 Users Online (128 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> How to draw a line less than 0.8mm in Revit
Wed, Mar 10, 2010 at 11:52:23 PM | How to draw a line less than 0.8mm in Revit
ichlove
Hi, is there anyone knows how to draw the line which is less than 0.8mm in Revit? And how to combine a arc and line into one polyline?Thanks
Thu, Mar 11, 2010 at 2:12:04 AM | How to draw a line less than 0.8mm in Revit
mcantwell
mcantwell Avatar
Edit the line weights.
Not sure there is a polyline. Select a line and tab and all the connected lines will be connected.
 What are you trying to achieve.
Edited on: Thu, Mar 11, 2010 at 2:14:01 AM
Thu, Mar 11, 2010 at 10:05:30 AM | How to draw a line less than 0.8mm in Revit
There is no polyline in revit but lines can be drawn in sequence and as such are selectable with one pick.... use your tab key.
If you are asking about line width then mcantwell gave you an answer but I believe you were asking about line length.  Revit will not deal with very short lines like CAD does.  This allows Revit to be faster... and after all, why would we be dealing with very-very short lines in buildings?  We don't work to those kind of tolerances.
Sat, Mar 13, 2010 at 5:08:03 PM | How to draw a line less than 0.8mm in Revit
mcantwell
mcantwell Avatar
http://revitfix.blogspot.com/2008/07/tips-with-symbols-generic-annotations.html
BRIAN RENEHAN revitfix blog has some tips
How to draw this property line?
Sat, Jan 23, 2016 at 4:48:19 PM
draw order in revit 2010
Tue, Sep 23, 2014 at 1:24:32 PM
How do I Draw a Wall Slightly (low angle) of Axis
Mon, May 13, 2013 at 3:16:46 PM
Revit 2010 - Can't pick a line for plane to draw extrusions - HELP!!!
Thu, Aug 27, 2009 at 3:34:26 AM
Flex pipe equivalent in 2d detail line component - to draw a multi-lane road.
Sat, Aug 27, 2016 at 3:57:44 AM
Page generation time: 4.7374
