101 Users Online (99 Members):
Forums >> Revit Building >> Technical Support >> I can't see an elevation symbol on a section?!
7 Posts No Rating |
On a section view of a project, I can't see an elevation symbol. I changed the view box of the section but cannot see my elevation line. Thanks
Do you mean a level line? If so, turn off crop regions. The level may be out of view and yoiu will have to drag it into the view range.
7 Posts No Rating |
Actually, the view is inside my crop region. I can see all the elements at this level without seeing this line?
Please reread my post - yopur solution is there.
18 Posts No Rating |
Nikesava sometimes the levels come in far larger than the drawing area, are dont show in the section, in which case you would have to do what WWhub says to resize them so they show up within the window. If that doesnt work, try checking that it isnt hidden in the view.
How do you change the look of the Elevation Symbol |
Thu, Sep 14, 2006 at 5:15:43 PM
Spot elevation symbol [ 1 2 ] |
Mon, Dec 1, 2008 at 10:10:59 AM
16
Elevation Symbol Help |
Tue, Jun 5, 2012 at 7:28:11 PM
elevation symbol showing too much information |
Fri, Jan 20, 2006 at 7:40:36 PM
Sink Family - Symbol Lines won't flex with Wall Change in Section View |
Mon, Mar 9, 2009 at 5:26:15 PM
Members: | 2017174 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
