30 Users Online (28 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Vanishing Title Blocks
Tue, Mar 9, 2010 at 1:42:15 PM | Vanishing Title Blocks
EugenioFV
So something happened in the project where every single sheet titleblock (all the plan, elevations, section etc. name tags) Just disappeared, when I place a new view into a sheet, it doesnt create a drawing title.
My guess is some visibility setting issue, but I cant seem to find what is causing this problem. Anyone that could steer me in the correct direction?
Thanks
Tue, Mar 9, 2010 at 1:54:30 PM | Vanishing Title Blocks
A view title for a sheet is a family that is definable or re-definable as it looks in your case.  Someone must have changed your default view title to none ... but you can redefine it.
Do a search of your HELP using "view title" and you will find topics on how to modify your view titles.
Tue, Mar 9, 2010 at 1:57:29 PM | Vanishing Title Blocks
EugenioFV
Yeah, by mistake the default type was changed to not display the titles.
Thanks, crisis averted!
Delete or Purge out Title Blocks?
Wed, Nov 26, 2008 at 5:06:01 PM
Customize new Title Blocks
Mon, Sep 21, 2009 at 2:55:20 PM
Sheets Title Blocks
Mon, Jul 6, 2015 at 2:30:17 PM
Title blocks
Mon, May 11, 2009 at 2:53:45 PM
creating custom title blocks
Tue, May 22, 2007 at 2:29:41 PM
Page generation time: 4.8186
