53 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Roomtags not showing up
Mon, Mar 8, 2010 at 9:20:11 PM | Roomtags not showing up
ike114
I am using Revit 2010 and am having a problem with roomtags.  When I move the roomtags outside of the room the tag loses it information.  I have tried it with the leader box checked and unchecked.  I really need to move the roomtags out of the room due to the size of the rooms, any suggestions?  Thanks.
Mon, Mar 8, 2010 at 9:53:18 PM | ramp
suman143
I am creating ramp in revit architecture but now i want estimation on it. But ramp catagory is not present in material takeoff. Please help.
Mon, Mar 8, 2010 at 10:38:21 PM | Roomtags not showing up
tabletennisman
Are you selecting both the actual tag, and also the room area when you try move it?
Mon, Mar 8, 2010 at 10:43:15 PM | Roomtags not showing up
ike114
No,  I am just selecting the roomtag.  Do I need to select the room area as well?
Mon, Mar 8, 2010 at 10:49:18 PM | Roomtags not showing up
tabletennisman
yea you have to select the tag + the area and move at the same time... click on the tag, then hold ctrl key on keyboard and select the area. then move both...
Mon, Mar 8, 2010 at 10:52:37 PM | Roomtags not showing up
ike114
Thank you I will try it tomorrow when I get to work.
Tue, Mar 9, 2010 at 7:09:17 AM | Roomtags not showing up
No... don't move the area.
All you have to do is turn on the leader and move the tag.  The leader will always point to the intersection of the X in the room area so you can move that intersection but if you move it outside the room, the room will no longer be bounded by the same boundaries.
Roomtags keep moving in wall sections
Tue, May 8, 2007 at 6:39:50 PM
scale check
Tue, Oct 23, 2012 at 5:05:09 AM
Cars not showing in renderings but showing in site plan, help hurry please
Fri, May 6, 2011 at 6:01:50 PM
Revit in revit linked file
Tue, Apr 8, 2008 at 9:13:42 AM
workstation room tags
Thu, Jun 14, 2007 at 8:03:40 PM
Page generation time: 0.3999
