Forums >> Revit Building >> Technical Support >> Spot Elevation Suffix Under tag
Fri, Mar 5, 2010 at 10:13:04 AM | Spot Elevation Suffix Under tag
leothelionator
When editing a spot elevation, I noticed that Lower Value, Lower Value Prefix, and Lower Value Suffix are all grayed out.  How do I enable them so I can add the suffix "T.O. Steel", etc underneath the elevation tag?
 So far I am only able to add the suffix to the elevation height on the upper end of the tag, but it ends up being extra long.  I would prefer the tag height on top, and the suffix description on bottom.
Spot Elevation tag
Tue, May 6, 2014 at 12:41:09 PM
Spot elevation Tag and Insulation
Wed, Jun 11, 2014 at 10:00:27 AM
Invert Elevation Vs. Spot Elevation
Mon, Apr 20, 2015 at 2:09:11 PM
Spot elevation tag issue
Mon, Jun 3, 2019 at 3:18:37 PM
ceiling tag to read as spot elevation (top or bottom elevation) (2017)
Tue, Aug 28, 2018 at 10:51:10 AM
Page generation time: 16.1955
