66 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> 2D Axonometric
Fri, Mar 5, 2010 at 8:36:28 AM | 2D Axonometric
edelong
We're doing simple floor plan space diagrams for a building fit-out, and wanted to stack 2D axonometric floor plans.  I know in 3D view you can orient the view NW, SW, etc., but its not practical to adjust the cut box to show a sliver of the floor plan.  And there's no way I can see to orient a plan view differently once placed on a sheet.  Is it possible to do this, or do I have to dust off AutoCAD and do it there?  Arch 2009, BTW...
Fri, Mar 5, 2010 at 9:27:57 AM | 2D Axonometric
TKennedy
4 Stars: 7 Votes
You can use "Orient To View" and pick a floor plan, then the 3D view will automatically use a section box to crop itself the same as the plan, including cropping vertically the same as the plan's view range (not sure I explained that very well). It will also be rotated to a top view, but you can easily rotate it back to a SW, NW etc. view.
Fri, Mar 5, 2010 at 9:37:14 AM | 2D Axonometric
edelong
But you still have 3D walls upto the cut plane.  I'm looking for a 2D plan shown axonometrically.  We're VERY early in schematics, to the point where we're showing line diagrams.  I know its counter-intuitive to what Revit brings to the table, but this is what the client wants to see at this point.
Mon, May 17, 2010 at 11:54:18 AM | 2D Axonometric
benjamenbuglovsky
I know its probably too late but for future reference to anyone needing to do this same technique like You and I both wanted to.
If you export your floor plan view as a dwg, then you can import it into a different project  [or perhaps into the same project] that way it will be a flat 2d line drawing. then you can go to your 3d view and choose one of the isometric view points and viola a floor plan shown as an isometric
Edited on: Mon, May 17, 2010 at 11:55:32 AM
Axonometric View labels and notes
Wed, Jul 8, 2009 at 4:55:58 AM
axonometric SCALED drawing
Sat, Apr 16, 2011 at 6:42:29 AM
exploded axonometric?
Mon, Jun 5, 2006 at 7:59:53 AM
Wed, May 2, 2007 at 7:48:16 PM
Can you create axonometric views?
Sun, Mar 4, 2007 at 7:10:29 AM
Page generation time: 0.1888
