80 Users Online (77 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Door frames
Fri, Sep 16, 2005 at 2:24:04 PM | Door frames
scampbell75
Hello. I have a really simple question. Is there any way to see a door frame in a plan view when using the door families included in Revit? If not, must I create my own door family to show the frame? Thanks. Sean C.
Fri, Sep 16, 2005 at 7:25:30 PM | RE: Door frames
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Of course. I believe the door families that come with revit are setup to display differently at different levels of detail... Try setting the view to medium or coarse detail level. If it still doesn't display, you'll have to resort to editing the family, selecting the frame, going to visibilty and retick show in plan.
Sat, Sep 17, 2005 at 6:14:10 PM | RE: Door frames
scampbell75
I tried changing the detail level and no frame appeared. I will have to build my own. Good practice I guess. Thanks for the info. Sean
Wrapping Door Frames and Internal Door Frames [ 1 2 ]
Mon, Aug 11, 2008 at 11:02:26 AM
15
Show Door Frames in Plan View
Wed, Aug 10, 2005 at 6:09:34 PM
Door Families with HM frames that center on walls.
Thu, Sep 21, 2006 at 9:15:16 AM
how to make door frames cut wall sweep? [ 1 2 ]
Mon, Jun 9, 2008 at 8:11:27 AM
20
Door and Window Frames not showing in Elevation
Thu, Dec 17, 2015 at 4:34:06 AM
Page generation time: 0.5353
