Forums >> General Discussion >> Revit Project Management >> Slight rotation in a single view
4 Posts No Rating |
Out of several plan views in my project, only one, an RCP view, has a slight rotation--maybe 1/2 degree or so--too small to measure. I have no idea how this got rotated and don't understand why only this one view is rotated. How do I get this back in square like the other plan views? I don't want to rotate the model, only the view of the model.
Rotate the crop boundary.
4 Posts No Rating |
Replying to my own post... I rotated the view from True North to Project North (supposed to be 90 deg.), then back to True North and the slight rotation was gone! Anyone want to explain that?
I'd say that unintentionally you've rotated the crop region slightly, this will affect only the current view. Changing to true then back to project seems to reset the rotation... OR your machine was possessed by some Revit beast/demon, holy water is another option...
1 Posts No Rating |
This is brilliant. Changing to True North then back to Project North resets the view rotation without having to delete and re-create the view. Thanks!
5 Posts No Rating |
Great Trick! Worked in Revit 2015
View Rotation |
Tue, May 24, 2011 at 1:20:51 PM
View Rotation on Sheet |
Thu, Jan 18, 2007 at 10:12:39 AM
View Rotation on a Sheet |
Tue, Feb 14, 2012 at 1:32:38 AM
view label rotation plan view |
Tue, Dec 30, 2014 at 11:17:51 AM
Tue, Oct 27, 2009 at 12:35:36 AM
Members: | 2104085 | Objects: | 23178 | Forum Posts: | 152298 | Job Listings: | 3 |
