62 Users Online (61 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Materials not showing in render
Thu, Mar 4, 2010 at 5:20:30 AM | Materials not showing in render
noliveira
Hi everybody,
 I recently upgraded to Revit 2010 from Revit 9 and i'm having some problems with some of the materials not showing on certain objects. (working on a project created with R9).
For example, some walls (same family as others) won't render the material I apply to them or the rails won't render the aluminum material, just to name a few.
 I know the problem is not the materials because I re-added them to make sure they were available on this version, but these objects continue to render as the standard white/grey mass. Phasing is also correct.
 Any clues on this?
Thanks,
Nuno
Thu, Mar 4, 2010 at 6:15:06 AM | Materials not showing in render
4 Stars: 203 Votes
Are you talking Revit 9 or 2009?
One thing about materials: PROJECT RULES, you can assign one material in a family but when you load into your project, if the material (same name) exist in the project BUT with other "material" (texture), it will render with the texture of the project an NOT with the family material (texture)....
Se tiveres alguma dúvida podes perguntar em Português...
Thu, Mar 4, 2010 at 6:19:43 AM | Materials not showing in render
HDDWG2003
HDDWG2003 Avatar
3.5 Stars: 11 Votes
I ALSO HAD SOME ISSUES LIKE THIS WHEN REVIT CHANGED OVER TO THE MENTAL RENDERING ENGINE
Wed, Jul 6, 2011 at 1:14:38 PM | Materials not showing in render
gryi
THAT IS GOOD TO KNOW
Renderings not showing materials
Tue, Mar 6, 2012 at 8:25:35 AM
Render materials lost link
Mon, Nov 30, 2009 at 9:36:59 AM
Import model from Sketchup to Revit- Materials not showing up in rendering
Wed, Mar 17, 2010 at 1:27:25 PM
Can't get any materials to render
Tue, Jun 2, 2009 at 9:49:29 AM
My jpeg materials keep missing
Thu, May 13, 2010 at 7:54:23 AM
Page generation time: 1.1250
