42 Users Online (41 Members):
Forums >> Revit Building >> Technical Support >> Assigning a material to an extrusion - Family creation
![PatrickReynolds Avatar](user_avatar/79669.jpg)
40 Posts No Rating |
Hello again. I am currently trying to make a special folding panel for use in my project. The framing is wood and the infill is brick, roman brick to be specific. I am trying to assign a material to the extrusions I used to create the form and the only ones available to me are default, default light source, default roof, default wall, glass and poche. Does anyone know how I can find wood an brick? Also, is it possible to specify the brick dimensions for the material? If not, is there a place I can get additional revit materials? One other question, does anyone have a link to a tutorial for family parameters? Thanks in advance.
![4 Stars: 19 Votes](/images/stars_4.gif) |
You need to either define the material in the family or give it a parameter so that you can assign a material in the project. If you click on the down arrow by the help button, there is a families guide. Click on that and follow the instructions to get the tuturial or the PDF.
Material Aligning on extrusion |
Fri, Sep 8, 2017 at 2:46:37 AM
Families |
Sun, Sep 3, 2006 at 11:11:10 PM
Placing materials on objects in a family |
Mon, Dec 17, 2012 at 12:30:34 PM
14
Applying material to extrusion |
Thu, Nov 6, 2014 at 10:28:03 AM
11
Assigning material to rails |
Fri, Oct 12, 2012 at 12:57:11 PM
Members: | 2022349 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
