90 Users Online (88 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Wall Mounted Handrail
Fri, Feb 26, 2010 at 8:42:30 PM | Wall Mounted Handrail
mmantegna
Does anyone have a wall mounted handrail I could download or know of a way to create a wall mounted handrail in revit?  I have tried using the railing tool, but couldn't delete the ballisters.  Thanks for your help.
Sat, Feb 27, 2010 at 4:14:39 AM | Wall Mounted Handrail
tim123
4 Stars: 19 Votes
The rail is just a normal rail.  Replace the balusters with the bracket (Bracket - Wall mounted handrail) from the library.  Adjust the spacing accordingly.
Sat, Feb 27, 2010 at 8:04:22 AM | Wall Mounted Handrail
A good resource is the on-line library.  I know ... I know ... it is no longer used in 2010!  Yes ... but the 2009 / 2008 stuff is still there!  Look in the 2009 location and you will find some sample projects - stairs - fences - handrails... Lodd up these projects and use them as a resource.  You will find preset stairs and handrails that you can copy/paste into your project and use.
Sat, Feb 27, 2010 at 5:16:53 PM | Wall Mounted Handrail
Kardiff
5 Stars: 3 Votes
generic wall mounted model
and give it some crazy parametrics
can make it to spec then
solid blend / sweep
and array the wall joints
- Just trying to help out while I wait in the office for my renders to complete
www.danrossiter.co.uk
Fri, Nov 26, 2010 at 1:10:40 PM | Wall Mounted Handrail
iamian33
iamian33 Avatar
silly question time ...
where can I find the old on-line library?  Is it Autodesk Seek?
Ian
Ian Shafer
Principal Consultant
True North S&F Consultants
Sat, Nov 27, 2010 at 7:42:18 AM | Wall Mounted Handrail
4 Stars: 203 Votes
Are you talking about this: http://revit.autodesk.com/library/html/index.html
or this: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=12827697
Sun, Nov 28, 2010 at 11:16:03 PM | Wall Mounted Handrail
iamian33
iamian33 Avatar
Merci Typhoon.
But the first link is to a french site.  It suggests that the english version is not located on Seek.  I am not a fan of Seek as it seems to be mostly a collection of manufacturer-created families ... and they are way over modelled and too large for use in an architectural model.
The second link delivered a small collection of structural steel families.
WWHUB suggested that prior to 2011, there was an on-line library of revit families, beyond the rfa files included with revit.  If this is so, I would appreciate it if someone can point me to this library.
Thanks, again.Ian
Ian Shafer
Mon, Nov 29, 2010 at 7:12:23 AM | Wall Mounted Handrail
iamian33,
  1. Seek includes the installed Revit library.
  2. Although some of the manufacturer content is overdone, that is not true for all of it.  You just have to take the time to look at the families.
  3. I did not say that there were additional "families" on the AutoDESK site but there are several resourcesthat are not in the library.  One should look at the "SAMPLE" items like stairs, railings, and repeating details.  The Library is located here:> http://revit.autodesk.com/library/html/index.html
Mon, Nov 29, 2010 at 10:56:37 AM | Wall Mounted Handrail
iamian33
iamian33 Avatar
thank you. ...
Ian Shafer
Handrail - Wall mounted
Fri, Apr 28, 2017 at 5:35:55 PM
handrail, wall mounted
Fri, Feb 13, 2009 at 1:47:37 PM
Stair handrail - wall mounted
Thu, Jul 7, 2016 at 3:25:12 PM
Glass Balustrade with side mounted handrail
Mon, Nov 18, 2013 at 11:31:01 PM
Thu, Jul 7, 2011 at 6:54:06 AM
Page generation time: 2.2243
