44 Users Online (43 Members):
Forums >> Revit Building >> Technical Support >> Referring View on View Titles
3 Posts No Rating |
When using AutoCAD, our office standard was to include the referring view on each view title (see attached for example). Revit obviously keeps track of where views are placed on sheets and where they are referenced from - is there a way to include the referring view (or views, in the case of typical details) in the View Title? Any help that I can get would be most appreciated!
You create and edit view title types using the Family Editor. Revit Architecture provides several view title types. Some default view title types include sheet numbers and referencing sheet numbers to provide cross-referencing information between views and sheets. You can read about this in your HELP. Edit a view title family and you will quickly see the parameters available to you.
3 Posts No Rating |
Thank you so much. I was able to incorporate the default family parameters into our custom title block.
Turn off view titles |
Tue, Jan 9, 2007 at 4:29:12 PM
VIEW TITLES |
Mon, Jun 18, 2018 at 10:24:52 AM
MULTIPLE VIEW TITLES |
Thu, Jan 31, 2013 at 5:46:51 AM
Right Align View Titles |
Mon, Jan 28, 2008 at 3:57:58 PM
View Titles problem |
Mon, Aug 25, 2008 at 10:42:35 AM
Members: | 2022285 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
