63 Users Online (62 Members):
Forums >> Revit Structure >> Technical Support >> Void Extrusion
2 Posts No Rating |
I'm in the process of doing the tutorial "Modeling a Box Gider Bridge" from Autodesk Revit. I'm having troubles using the void extrusion command on a column. I get it to work in the family, but when I load it into the project, it cuts out my box girder which is shown in the rendering attached. I've tried doing the void extrusion from plan view, and froma side elevation. Nothing seems to working. Please help!
![5 Stars: 3 Votes](/images/stars_5.gif) |
Maybe your void is too large, try locking it into the top of your family, or try making it without a void as a conecptual mass instead
- Just trying to help out while I wait in the office for my renders to complete www.danrossiter.co.uk |
void extrusion not cutting solid extrusion |
Fri, Oct 10, 2008 at 3:47:43 PM
Make void extrusion permanent |
Wed, Feb 9, 2022 at 6:46:57 PM
Void Extrusion in window family problem |
Mon, May 18, 2015 at 3:55:23 PM
Void Extrusion |
Tue, May 28, 2013 at 8:15:38 PM
Cut a void from an extrusion |
Thu, Feb 19, 2015 at 1:08:44 AM
Members: | 2022243 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
