80 Users Online (77 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Curtain wall panels changing materials when pinned
Thu, Feb 25, 2010 at 9:52:31 PM | Curtain wall panels changing materials when pinned
nklank
I created curtain wall where parts of the curtain wall are the regular wall condition.  However, when I pin all of the panels to the regular wall condition, they all turn back to glass.  What do I need to differently to avoid this?
Fri, Feb 26, 2010 at 2:51:25 AM | Curtain wall panels changing materials when pinned
Kardiff
5 Stars: 3 Votes
Use solid a panel where the parts aren't glass and give that the regular wall material colour/bump.  Im not a big fan of pinning, I just leave everything as they are
- Just trying to help out while I wait in the office for my renders to complete
www.danrossiter.co.uk
Fri, Feb 26, 2010 at 8:46:06 AM | Curtain wall panels changing materials when pinned
nklank - You are using a preset storefront.
You can create storefronts with any or all components and/or spacings preset.  When you use these, you need to be aware that Revit will always try to restore the preset conditions unless you disable that function.
Preset storefronts are great for initial placement but after I place them, I like to change the type to one that has no pre-set conditions so that I can alter them.  Note ... when Revit warns you "Type associated gridlines..." do not delete the gridlines.  If you do, you willloose all your mulliuons and panels but otherwise, everything will remain in place.
Curtain Wall - Panels Totally Un-editable
Mon, May 8, 2017 at 6:36:18 PM
Curtain wall panels following profile
Wed, Oct 12, 2011 at 8:41:58 AM
Replace blank curtain wall panel
Mon, Oct 12, 2015 at 12:13:57 PM
Can Adaptive Panels Be Used in A Curtain Wall
Mon, Jun 9, 2014 at 1:49:37 PM
Raised Glass/Metal Panels for Curtain Wall
Thu, Dec 20, 2007 at 6:43:05 PM
Page generation time: 2.1636
