46 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Trying to create Curved Mullions inside a curtain wall
Thu, Feb 25, 2010 at 6:27:41 PM | Trying to create Curved Mullions inside a curtain wall
Elemental25
I have been trying to find a way to create a curved mullion inside of a curtain wall but seem to be coming to all dead ends....any ideas?
Wed, Mar 3, 2010 at 9:45:09 AM | Trying to create Curved Mullions inside a curtain wall
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
Mullions layout are created using grids - which unfortunately do not have any options for curved/arc grid lines. (I wish they do!). You might have to model in-place.
 "If you tell the truth, you don't have to remember anything"
Wed, Mar 3, 2010 at 10:05:46 AM | Trying to create Curved Mullions inside a curtain wall
Thread Post Kudo! #3
3.5 Stars: 395 Votes
You can't create a curved mullion inside a curtainwall .... BUT ... you can edit the profile of a curtainwall and have curved mullions at the edges..... so ... think out of the box... edit your curtainwall profile and cut a hole in it.  The edges of the hole will have curved mullions.  Now place another curtainwall that has been edited to be a circle to fit in the hole.
Wed, Mar 3, 2010 at 10:16:30 AM | Trying to create Curved Mullions inside a curtain wall
Here is what you can do....
Wed, Mar 3, 2010 at 10:59:54 AM | Trying to create Curved Mullions inside a curtain wall
oMarNSE
How did you create that wall wwhub?
i have a wall thats mainly window except the lower half F.F to 3'
can you help?
Wed, Mar 3, 2010 at 11:04:34 AM | Trying to create Curved Mullions inside a curtain wall
That is two curtailwalls end to end.  Just modified the profile of each to be the curve and one has the curved mullions - the other has no mullion at the curve.
Wed, Mar 3, 2010 at 11:46:08 AM | Trying to create Curved Mullions inside a curtain wall
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
That's very nice WWHub!!! I also wish that they you can create a curve/arc grid lines so you can simply add mullions to it. The two curtain wall will work out well with just one curving mullion (like what you have in the picture). but what if you need to put like 10 mullions of the same? I'm guessing you need to create 10 curtain panel as well. wishlist?
Wed, Mar 3, 2010 at 11:57:35 AM | Trying to create Curved Mullions inside a curtain wall
If I needed to do ten, I would only do one large panel with an in-place family that was all my curved mullions.
Wed, Mar 3, 2010 at 12:14:42 PM | Trying to create Curved Mullions inside a curtain wall
Elemental25
Thank you very much! This was very helpful.
Wed, Mar 3, 2010 at 3:27:28 PM | Trying to create Curved Mullions inside a curtain wall
Elemental25
I was able to create the curved mullions by cutting them out but i was also wondering if you were able to do this on a curved storefront. I have been trying to find someway to edit the profile but wheni create a curved storefront i am not able to.
Wed, Mar 3, 2010 at 3:43:30 PM | Trying to create Curved Mullions inside a curtain wall
You really can't do a curved storefront in plan ... just a segmented storefront because you really don't want to curve glass.  Any segment could be one storefornt and modified.
But if you want something else, do in-place model elements and don't try to force Revit's stock tools to be this unique.
Curtain wall with splayed mullions
Tue, May 10, 2016 at 2:05:31 PM
curved curtain system -diagonal grid system?
Wed, Feb 11, 2009 at 4:24:47 PM
Curved Mullion within Curtain Walls
Mon, Oct 5, 2009 at 6:09:39 AM
Angled and Straight Curtain Wall Mullions
Mon, Feb 27, 2012 at 12:19:11 PM
Arched Curtain Wall Arched Mullions
Wed, Jan 22, 2020 at 2:13:08 AM
Page generation time: 2.4462
