45 Users Online (44 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> pipe types
Thu, Feb 25, 2010 at 2:22:36 PM | pipe types
vinnygolfer
4.5 Stars: 4 Votes
using mep2010, i saw a tutorial that showed making a plumbing system. in that tutorial they had "vent" in another color. but they never went into how to set up the filter or connector, or whatever they had to setup to show the vent in a different color. i need to know that as well as showing storm drain different from sanitary drain. plz advise.
thank you
Try to learn at least one new thing every day
Thu, Feb 25, 2010 at 4:11:48 PM | pipe types
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
I would use a filter to handle this. In the default template, there are some pre-existing filters already in place.
 check this thread to see if it is what you are looking for.
http://www.revitcity.com/forums.php?action=viewthread&thread_id=18588
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Thu, Feb 25, 2010 at 9:47:50 PM | pipe types
vinnygolfer
4.5 Stars: 4 Votes
awesom, that was exactly what i needed to know.
thank you so much
Fri, Feb 26, 2010 at 9:00:21 AM | pipe types
brettgoodchild
4 Stars: 17 Votes
Glad I could help! Smile
                             ~ Abraham Lincoln
Fri, Feb 26, 2010 at 9:09:12 AM | pipe types
vinnygolfer
4.5 Stars: 4 Votes
thanks again, i don't know if you can help with the other post i had or not. i was wondering if it's possible to place a leader with no text. basically i just want to place flow arrows without having to make a filled region and copy it all over the place.
Fri, Feb 26, 2010 at 9:38:42 AM | pipe types
brettgoodchild
4 Stars: 17 Votes
I should note, that if you have your systems defined in your model, that you can also add piping and duct legends
from the Analyze tab. There are some defaults in there and one of which will add a color fill based on system name.
Maybe easier than the filters...less management I suppose.
In the images from my previous post I had to use filters as I had no systems defined...the RFP only required and model so we didn't budget for the intelligence.
For your flow direction, I'm not too sure about that. I could dig around and see what I can find, but if there is nothing natively in Revit to display it, I would consider making a line based detila component for this. Initial thought anyways.
                             ~ Abraham Lincoln
Fri, Feb 26, 2010 at 11:47:12 AM | pipe types
3.5 Stars: 396 Votes
Vinny,
There is a no-text leader family in the downloads area ... search leader and you will find it.
Fri, Feb 26, 2010 at 12:25:33 PM | pipe types
vinnygolfer
4.5 Stars: 4 Votes
thanks, i found it. works very well
Pipe Accessories and Pipe Type parameter
Tue, Dec 27, 2011 at 11:25:39 AM
Revit MEP 2012 - Transfer Pipe Size & Pipe Materials bug?
Fri, May 18, 2012 at 10:04:27 AM
Trim HSS Round pipe into another HSS Round pipe
Tue, Apr 3, 2012 at 4:39:45 AM
Export Model to AutoCAD - Layers, Pipe Types, Filters
Thu, Oct 11, 2012 at 2:18:26 PM
Quantities & Schedules for Pipe Types (Sorted Per Level)
Wed, Sep 21, 2011 at 7:24:33 PM
Page generation time: 0.5292
