30 Users Online (27 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Window Mullion Problem
Wed, Feb 24, 2010 at 3:43:16 PM | Window Mullion Problem
WIArchitect
In my quest to learn revit I am trying to create an existing building that I did in cad. I have a situation where I have a split window. I built both sections as curtain walls and inserted the mullions as required. (see attached) the grey area between the mullions is where I need to fill in. That area in the project has an insulated metal panel (instead of glass) inserted between the top and bottom mullions. I have though of 3 possible ways to do it.
1. Build a 3rd curtain wall in theat space and make the glass opaque. (Which I think I can figure out.)
2. Some how extend the vertical mullions from the bottom widow up to the top of the top window and somehow fill the area in.
3. Create a curtain wall the full height, fill in the mullions as required and somehow turn just the glass section I need to be an opaque section.
 What do you people think? And if you tell me 2 or 3 what is the easies way to do either of those?
 Thanks
Wed, Feb 24, 2010 at 3:50:23 PM | Window Mullion Problem
WIArchitect
viewable file for above.
Wed, Feb 24, 2010 at 3:56:34 PM | Window Mullion Problem
WIArchitect
I figured it out. Thanks if you were going to respond.
Mullion
Sat, Oct 17, 2015 at 9:53:55 PM
Mullion Array gone Arry
Thu, Oct 5, 2006 at 9:17:11 AM
Window Family issue - Revit 2012
Sun, Jun 12, 2011 at 11:12:59 AM
problem with horizontal mullion
Mon, Oct 31, 2011 at 2:44:40 PM
Window Family Problem
Fri, Jul 31, 2009 at 1:32:19 PM
Page generation time: 2.1947
