70 Users Online (69 Members):
Forums >> Revit Building >> Technical Support >> How to create a steel grid
13 Posts No Rating |
Does anyone know if there is a tool to create a steel/metal grid, or if there is an easy way of doing this? Using the bracing or framing tools just seems very tedious. I am trying to create a grid approx. 60' wide and about 30' tall compose of light guage steel tubes.
Hello, I'm not sure about a tool out there that does that, but you could create a generic model line based family and load the tube family...but if you don't have the time to do that you could use the array tool, then group them (vert. and horiz members) together. With array you have the option of grouping and constraining, so you would be able to stretch it, add more, etc. Not sure if that helps, but hope it does.
An image of what are you trying to do will help in the answer...
Grid Lines at Face of Steel, Not Centerline |
Thu, Mar 19, 2015 at 3:16:30 PM
Steel beam grid |
Tue, Aug 28, 2007 at 1:11:33 PM
How to Create Structural Steel in Revit MEP 09? |
Thu, Apr 2, 2009 at 2:08:56 PM
how to create diagonal grid!!? |
Sat, Apr 12, 2014 at 2:53:55 AM
True plan view of sloped steel? |
Mon, Feb 27, 2017 at 9:31:22 AM
14
Members: | 2016919 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
