Forums >> Revit Building >> Technical Support >> Exterior Wall Finishes
2 Posts No Rating |
Hi, I’m trying to make my exterior walls have a sandstone finish to fit in with Edinburgh architecture and not having much luck with it. Would appreciate any help to shed a little light on to where i could find a good wall finish or how to do it myself. Thanks
Do you have the material (sandstone finish) texture image? if so, just go to materials, duplicate a default material and use that texture/image....
" Hi, I’m trying to make my exterior walls have a sandstone finish to fit in with Edinburgh architecture and not having much luck with it. Would appreciate any help to shed a little light on to where i could find a good wall finish or how to do it myself. Thanks " if you've already tried and failed, please tell us where you are having problems. otherwise, it should just be a matter of setting the material appearance for the wall. check the material you have set for the structure of the wall, play with some stock finishes, then try your hand at tweaking the rendering settings.
qab
^_^
Debian + VirtualBox + Revit
2 Posts No Rating |
I don't have a default sandstone finish in my library. Is there somewhere I can download it from or has it to be setup manually? Thanks for the help.
Try here: http://www.imageafter.com/textures.php or here: http://www.mayang.com/textures/ or here: http://www.cgtextures.com/
Exterior finish on wall not exterior enough... ? |
Fri, Jun 3, 2011 at 8:44:29 PM
Creating different Masonry walls with different finishes |
Sat, Feb 4, 2012 at 9:07:03 PM
Internal Wall Finishes |
Tue, Mar 25, 2014 at 4:18:19 PM
concrete panel system not sure what the best method it *****picture included |
Mon, Feb 2, 2009 at 8:38:12 AM
Creating a wall finishes schedule, and coding wall finishes on elevations |
Fri, Jun 1, 2012 at 4:06:33 PM
Members: | 2100554 | Objects: | 23171 | Forum Posts: | 152293 | Job Listings: | 3 |
