66 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Made a new family but ant rotate it properly
Tue, Feb 23, 2010 at 2:44:05 PM | Made a new family but cant rotate it properly
jcrocco
3 Stars: 1 Votes
Made a new family that needs to be able to rotate Horiz and Vert.  When I insert it, I can rotate it in the plan view, but when viewed from an elevation view, I cannot rotate it.
This is for MEP2010, and I used generic model as my family template.
I thought it was something to do with dimensioning from level 1, so I made a new ref plane, and dim from that, and it didn't work.
I then made a new family again using generic model, just made a simple rectangle, no parameters or dimensions, loaded it into the project, and it still wont rotate in elevation view.
Is there a switch or some other template I need to use?
Very frusterating.
File Attached . .
Edited on: Tue, Feb 23, 2010 at 2:54:46 PM
Wed, Feb 24, 2010 at 1:35:44 PM | Made a new family but ant rotate it properly
4 Stars: 203 Votes
I don't work with MEP but see if this help you...
Fri, Feb 26, 2010 at 1:17:05 PM | Made a new family but ant rotate it properly
jcrocco
3 Stars: 1 Votes
Well, What I found out is that a general template is somehow locked to the level.  I would have thought that it would  be unbounded, as it is a general template.
I had to use a mechanical equipment template, and it allowed me to do what i wanted.
A third party tech support company spent two hours on it as they didn't know why it wouldnt work either.
It would be nice to have a description as to when certain templates should be used, and when they shouldn't.
Mon, Jun 13, 2011 at 11:26:52 AM | Made a new family but ant rotate it properly
Gottfried
I tried this:
see attached file( I used jing to record that)
keypoints. the family has to be created on a rotatable host inside the family.
once you create that family it can be rotated in a project with the normal rotate command, but the angel relative to the horizontal plane can be controlled over a parameter, which is controlling the host plane inside that family.
did that help a little?
Mon, Jun 13, 2011 at 12:22:29 PM | Made a new family but ant rotate it properly
Gottfried
<a href="http://www.screencast.com/t/leG4FrUHux">parametric_family_with_rotated_host_plane</a>
thats the link to my previous comment
Mon, Jun 13, 2011 at 12:32:45 PM | Made a new family but ant rotate it properly
Gottfried
the upper link doesn't work ...sorry!
this one should be fine:
Can't Rotate Revit Family Created
Mon, Dec 3, 2012 at 2:21:24 PM
How to rotate a familly and have its texture rotate with it ?
Thu, Jul 19, 2012 at 1:00:19 PM
Rotate of family
Wed, Feb 24, 2010 at 1:32:32 AM
rotate PROJECT north (not true north)
Wed, Jun 10, 2009 at 9:11:40 AM
Parametric sliding window family not showing properly in plan
Wed, Apr 6, 2011 at 10:04:59 PM
Page generation time: 1.1567
