54 Users Online (53 Members):
Forums >> General Discussion >> Revit Project Management >> AutoCad Architecture or Revit
1 Posts No Rating |
Dear RevitCity' member I am architect woring in saudi arabia i am brand new in BIM solution there is a dialectic in my office about using ACA (AutoCad Architecture) or Revit i want to here from you what is advantage / disadvantage between the two applications thanks a lot to you and your world Ahmed Maher SR. Architect / ZFP
I think you should visit the AutoDESK website. There are some good whitepapers that deal with the advantages of Revit. Comparing Revit to AutoCAD is like comparing a Racehorse to a donkey. They are really not comparable. Although Revit has CAD functions and is actually better at CAD for buildings than AutoCAD, Revit is not CAD. And although AutoCAD Architecture tries to be BIM, it is not. Think about this too....since AutoDESK is pushing Revit, I believe AutoCAD Architecture is on its way out.
![coreed Avatar](user_avatar/14568.jpg)
There are no advantages to using Autocad Architecture over Revit. PERIOD !! Go with Revit !!!!!!!!! hth
![4.5 Stars: 25 Votes](/images/stars_4.5.gif) |
This subject has been discussed at length on this and other forums. Bottom line do your research and choose wisely. Personally you would never get me to go back to a CAD based solution. Revit = Database that can do architectural graphics (80% data, 20% graphics) = Future ACA = Graphic engine that can handle a little bit of data. (80% graphics, 20% data) = Past
Autocad Architecture join the Revit Architecture Suite |
Tue, Aug 19, 2008 at 9:14:55 AM
Just received New Revit Architecture Bundle |
Mon, Sep 22, 2008 at 6:26:19 PM
Walls Imported from AutoCAD Architecture 2009 |
Thu, Nov 11, 2010 at 11:30:08 AM
Linking 3D Dwg files from AutoCAD Architecture to Revit MEP |
Thu, Aug 26, 2010 at 7:48:24 AM
migrating from autocad architecture to revit |
Sun, Oct 14, 2012 at 4:36:34 PM
Members: | 2017256 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
