148 Users Online (147 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Isometric Views and Dimensioning
Mon, Feb 22, 2010 at 12:02:28 PM | Isometric Views and Dimensioning
emmettking
I have created a isomteric view of a stone still.  I used the orient to view command to create my view.  Now i would like to dimension the stone sill but when i do this it creates the dimension off in space no wheree close to where i am dimensioning or the faces, points or edges of what i am dimensioning.  Anyone have this problem or solved this problem?
 Oh yeah working in Revit Architecture2010.
Thanks,
Mon, Feb 22, 2010 at 1:00:38 PM | Isometric Views and Dimensioning
4 Stars: 202 Votes
First select the "Work plane" you want to create the horizontal dimensions, then choose another "Work plane" for the vertical dimensions.
Mon, Feb 22, 2010 at 3:20:23 PM | Isometric Views and Dimensioning
emmettking
Typhoon that worked like a charm.  Setting the right work plane to go with the right dimensions (vertical and horizontal) was a little tricky but it looks great. thanks,
Isometric Dimensions in Drafting Views (details)
Fri, Sep 28, 2012 at 3:13:09 PM
Revit doesn't show Autocad isometric drawings
Thu, Nov 27, 2014 at 10:27:04 AM
Isometric Views & Scale
Fri, Aug 20, 2010 at 11:18:08 AM
Isometric Details
Fri, Apr 9, 2010 at 1:31:30 PM
callouts, isometrics, and tagging
Thu, Feb 19, 2009 at 8:04:12 AM
Page generation time: 0.4133
