74 Users Online (73 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Tips & Tricks >> Revit TotD – 2.22.10 | Save the trees, use DWF Markups!
Mon, Feb 22, 2010 at 9:39:08 AM | Revit TotD – 2.22.10 | Save the trees, use DWF Markups!
rkitect
rkitect Avatar
4 Stars: 29 Votes
With the environmentalists on the rise again, it’s more important than ever for us architects to try to save as many resources as possible.  We all know how much of a paper hog an average size architecture firm is, much less the large ones!  Here is a process that I push in all offices that I work in to help do their part in environmental responsibility, PLUS a few efficiency benefits to boot!
Using DWF Markups is ridiculously easy considering how powerful of a tool it is.  Let’s take a look at the process.
The first thing you need to know about the process is that markups only work on DWFs that are exported from Sheet views in Revit.  While this tip does not go through the export and markup process, I can assure you it is very simple.  Once you have a DWF marked up and ready to be used in your project.  Go ahead an import it back in to your sheet view.
Note that you do not have to be in your sheet view to import the markups, as the linking dialogue tells Revit which sheet in the DWF belongs to which sheet in Revit.
Once you have the DWF sheets linked up to their respective Revit sheets, click OK to load the Markups.
You can now see any markups that someone has placed in the DWF and how they correspond to the sheet.  Each markup is an individual object with its own properties.
You can see in the properties that you can change the status of these markups to either Question, Needs Review or Done.
You can add notes to the markup for the reviewer or future users…
..and you can see who has worked on this markup in the past as well as who created it to begin with.
Once you are complete with the markups, you can save the changes back out to the DWF for the project manager to review
There you have it.  A very easy to use tool, with very powerful implications.  A great way to save on paper, keep track of your revision process and efficiently review your projects!
Thanks again for stopping by.  Please feel free to comment and I hope you come back for another tip of the day!
As always, you can view this tip in its entirety at http://revittotd.com/02/846
-Carl Gibson
Revit no allowing me to save updates to DWF markup set
Thu, Oct 23, 2008 at 5:44:11 PM
DWF
Tue, Mar 27, 2007 at 10:19:52 AM
Save as DWF only?
Tue, Jul 6, 2010 at 4:51:04 PM
Revit views to DWF format to print
Fri, Mar 19, 2010 at 12:21:41 PM
help! dwf for 2d plans
Sun, Feb 26, 2006 at 8:15:57 PM
Page generation time: 1.6521
