Forums >> Community >> Newbies >> Families
Sat, Feb 20, 2010 at 6:55:17 PM | Families
rcurrent
If a family is created in version 2009 will it work in 2010?   The only family guide I've been able to download is 2009.
Sun, Feb 21, 2010 at 5:37:11 AM | Families
4 Stars: 203 Votes
YES, but the reverse is not possible... here is the tutorials in the 2010: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=13376394
Edited on: Sun, Feb 21, 2010 at 7:09:37 AM
Sun, Feb 21, 2010 at 6:11:43 AM | Families
rcurrent
Thank you, do you know if this set contains the one for making a generic threaded elbow?  I may have already downloaded that series and will have to check.  Presently I'm trying to use the printed 2009 tutorial I have but using 2010 version as I go through the exercise. It's a tester.  I think I've I've identified the trouble point in the area where you place an arc and dimension same.
Thanks again, RMC
10 New REVIT 8.1 'Families' Video Tutorials released
Tue, Oct 2, 2007 at 12:39:43 PM
Edit Default Families
Sun, Jan 24, 2010 at 8:23:42 AM
Revit Families
Fri, May 24, 2013 at 4:23:33 PM
12
Replacing Multiple families in a Project.
Mon, Oct 15, 2018 at 10:34:29 AM
Rendering Families in Revit 2010
Mon, Jul 19, 2010 at 5:39:45 AM
Page generation time: 2.1586
