Forums >> Revit Structure >> Tips & Tricks >> Revit TotD – 2.19.10 | Dimension Formulas
Fri, Feb 19, 2010 at 10:29:46 AM | Revit TotD – 2.19.10 | Dimension Formulas
rkitect
rkitect Avatar
4 Stars: 29 Votes
Gonna finish up the week with a very easy tip, yet very powerful for those complicated designs that use all those mathematical formulas and what not…
Hopefully, by this point, you know that you can simply enter a length to determine a wall or line length, or really anywhere you can input a dimension.  Simply type 100′ and hit enter et voila! 100′ of whatever you were placing.  Did you know, however, that you can do the same thing but with formulas!?
It’s very simple.  Instead of typing the normal dimension in like this:
You instead begin it with an ‘=’ like this:
You can use any formula context that revit allows.  I would suggest searching in help for “formula” to find out the terms and syntax that you can use.
Like I said, simple and quick, just like we like it here at Revittotd.com!  Hope you learned something, and thanks for stopping by.  Hope to see you again soon!
As always, you can view this tip in its entirety with video at http://revittotd.com/02/831
-Carl Gibson
Revit TotD – 10.12.09: Revit’s “Center” Command
Mon, Oct 12, 2009 at 10:56:00 AM
Understanding Formulas
Tue, Nov 16, 2010 at 1:36:05 PM
14
Revit TotD – 7.5.09: Let that Bump do the Work
Wed, Aug 5, 2009 at 9:52:58 AM
Revit TotD – 7.29.09: Don’t Skip the SKP Mats
Wed, Jul 29, 2009 at 9:24:55 AM
Revit TotD – 7.16.09: Is Reference Is Useful (ref plane parameters)
Thu, Jul 16, 2009 at 12:01:02 PM
Page generation time: 4.4456
