62 Users Online (61 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Intersecting sweeps
Wed, Sep 14, 2005 at 2:27:19 PM | Intersecting sweeps
TracyA
If anyone knows how to resolve this please let me know. I have a corner tower element on a project with arched cornices on two faces that need to miter at the corner. I created a profile of the cornice and then created a sweep path, however when the two sweeps come toghether at the corner they intersect rather than join. I've attached an image if it helps. Any help would be greatly appreciated. Thanks
Wed, Sep 14, 2005 at 4:41:51 PM | RE: Intersecting sweeps
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Because the two sweeps have different work planes they won't automatically mitre. You can create a new in-place family as a roof element and create voids to cut the fascias on the 45 to have them mitre. Use the cut geometry tool before finishing the family in order to have them cut... HTH.
Thu, Sep 15, 2005 at 9:30:35 AM | RE: Intersecting sweeps
TracyA
Thanks Mr. Spot - worked perfect.
intersecting elements problem
Tue, Sep 15, 2009 at 11:25:17 AM
Intersecting roofs
Mon, Oct 16, 2006 at 8:28:41 AM
Intersecting shapes in Wall edit profile (revit 2012)
Sun, Nov 10, 2013 at 8:42:11 PM
Intersecting Sweeps
Thu, Apr 27, 2006 at 3:40:37 PM
Problem connecting wall sweeps (horizontal and vertical)
Fri, May 4, 2012 at 2:07:26 PM
Page generation time: 1.5238
