50 Users Online (49 Members):
Forums >> Revit Structure >> Technical Support >> can you get tonnage or weight from the schedules command?
5 Posts No Rating |
Im trying to get the total weight of steel, can this be done?? thanks
![5 Stars: 3 Votes](/images/stars_5.gif) |
If you edit your steel elements in edit family to include a weight setting, you can then put it into your schedule. Easiest way i imagine would be a volume paramater ' = (height x width) + (flange width x width)*2'weight (kg) '=voume x XYZ' you can then add weight (kg) as a column in your shedule
- Just trying to help out while I wait in the office for my renders to complete www.danrossiter.co.uk |
2'weight (kg) '=voume x XYZ' should be on a seperate line in my post, and a seperate parameter in your family
Schedules for Steel Tonnage |
Thu, Oct 29, 2009 at 8:48:44 AM
Steelwork Tonnage - Schedule |
Thu, Aug 28, 2008 at 6:11:02 AM
Tonnage / Floor Area Schedule |
Thu, Apr 6, 2023 at 6:47:58 AM
Revision schedules |
Tue, Jan 17, 2006 at 11:29:52 PM
import/export line weight setting - is it possible between two projects? |
Tue, Jan 22, 2008 at 10:06:09 AM
Members: | 2022246 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
