93 Users Online (92 Members):
Forums >> Revit Building >> Technical Support >> Importing Autocad to Revit, adding details and notes, then back out to Autocad
5 Posts No Rating |
I am using Revit 2009. I have been using Revit for several years...seasoned I would say...single person firm. I had a fellow architectural firm ask if I could help get them through a deadline. I've checked out what they want me to do and it should be no problem. I know I can do the work if I can get the technology worked out. I know Revit, I don't know Autocad. So, they had done a roof plan and quite a few details in Autocad. What I want to do is import several sheets of the project, the roof plan w/ title block and then several detail sheets. I want to add text to the plan and then draw some of the details (some I can cut and paste and add information to them.) Then when I am done, I need to be able to export the sheets to Autocad so they can add the sheets to their set and have a Autocad file.  Using Revit more like drafting in 2D.) It seems like it should be doable, but I didn't find much in my search in the forums. I am now dreading I made a promise that isn't doable. Any help or direction to tutorials or even if you said that I am crazy and not to try to do it...
Autocad Text imported |
Tue, Dec 4, 2007 at 9:29:14 AM
Autocad details linked into Revit |
Mon, Jun 6, 2016 at 1:54:23 PM
Autocad details with hatch showing as black/solid |
Wed, May 22, 2013 at 11:47:29 AM
Revit looking Like AutoCAD |
Tue, Oct 4, 2011 at 4:41:28 PM
text in imported autocad drawing |
Wed, Apr 9, 2008 at 2:20:58 PM
Members: | 2030582 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
