103 Users Online (101 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Create unequal seat joist?
Thu, Feb 18, 2010 at 9:56:46 AM | Create unequal seat joist?
nikesava
Is there a possibility to create a joist with an unequal
I need a seat of 100MM thick on one side and 150mm on the other.
Thanks
Thu, Feb 18, 2010 at 10:46:19 AM | Create unequal seat joist?
TKennedy
4 Stars: 7 Votes
Yes. In the joist family, change the seat depth parameter to "Seat 1" (or whatever you want to call it), then on the other end replace the existing seat parameter with "Seat 2".
Thu, Feb 18, 2010 at 10:58:54 AM | Create unequal seat joist?
nikesava
I'm in the joist family editor and can't find the place to modifiy the "seat" length
Thu, Feb 18, 2010 at 2:46:58 PM | Create unequal seat joist?
TKennedy
4 Stars: 7 Votes
It may not be parametric. If you don't see a parameter controlling it, it is likely constraned to work planes, or possibly with dimensions. If it is controlled with a locked dimension, just unlock the dimension and assign a parameter to it. If it's controlled with planes, you may be able to just dimension the work planes and assign a parameter to that dim. You'll have to be careful that there is nothing else controlled with those planes though.
Sloped joist seat
Wed, Oct 24, 2012 at 1:26:12 PM
Joist Seat Elevation?? HELP!!
Fri, Apr 11, 2008 at 10:35:50 AM
Joist Seats of Unequal Depths
Thu, Jun 12, 2008 at 9:19:50 AM
Different seat depths same joist?
Wed, Nov 11, 2009 at 6:32:11 PM
bar joist seat depths
Mon, Nov 21, 2011 at 2:49:45 PM
Page generation time: 0.7867
