Forums >> Revit Building >> Technical Support >> Steel connection plates families
Tue, Sep 13, 2005 at 1:35:18 PM | Steel connection plates families
Pamfi
Hi, Are there any families available for steel plate connection in between colums-beams or girders? Or do I have to create ones? Also any bolts or screws available to be insrted for detailing the connections? And very important - can these be extracted into a schedule? Thank you, Florin
Tue, Sep 13, 2005 at 6:17:05 PM | RE: Steel connection plates families
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Are you using Revit Structure? I'm not familiar with the base families that come with the package and if its has the same limitations with regards to detail as revit building (i assume it would) In which case modelling bolts and screws would not be adviseable. Maybe a simple family made up of a model line with a circle at the top would suffice as this should create to much overhead as to actually creating a solid. If they are done as a family then use they could be extracted into a schedule.
Fri, Jun 21, 2013 at 1:43:40 AM | Steel connection plates families
caddeva
if you are using revit upgrade versions,you can get the Plugins -(SDS/2 Connect) from below link
http://sds2connect.com/
steel connection
Tue, May 13, 2008 at 4:48:49 AM
Connections in steel frames
Tue, Nov 11, 2014 at 2:44:10 AM
Framing Plates
Mon, Dec 14, 2009 at 8:25:13 PM
Need Help on Sloped Beam-Column Connection
Fri, Apr 29, 2016 at 1:50:43 PM
Steel Beam to Beam Connection
Fri, Jun 18, 2010 at 1:54:36 PM
Page generation time: 0.4767
