86 Users Online (85 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Modifying Split Face
Wed, Feb 17, 2010 at 4:13:24 AM | Modifying Split Face
Bhavani
Bhavani Avatar
I have already looked in the HELP but no use. I created a false Celing layout of 600 X 600 for the entire room and split Face of the false ceiling and applied material in the edge as Plaster Board. I am facing 2 problems
1. I am not able to modify the split face profile . i checked all the tabs its not lettin me modify the boundary of the split face. edit boundary is only letting me edit the ceiling profile. i tried to TAB n select the split face but no use.
2. In the material take OFF am gettin the area of the 600 x 600 as the entire area and the plasterboard Area. its not calculating the difference. I tried painting another material to the actual mineral fibre zone.Then it displayed the total and the split up. It is displaying some "Default" and entire area once and they by Celing Tile and then the Split up of the material.it ll be very difficult to work this way when there r so many rooms
AM attaching the files for reference.
Thanks!
Wed, Feb 17, 2010 at 8:43:23 AM | Modifying Split Face
You need to tab over the split line - not the edge of the ceiling.
If you are doing material take-offs - you need to understand how Revit provides this information.  Split areas are not removed from the base material so you have to remove that using excel or another program.
It is far easier to have two ceilings.
Wed, Feb 17, 2010 at 1:05:59 PM | Modifying Split Face
Thread Post Kudo! #3
4 Stars: 202 Votes
Try this: select by crossing, go to the filter then check only "Split Face" then edit...
Thu, Feb 18, 2010 at 12:14:05 AM | Modifying Split Face
Bhavani
Bhavani Avatar
I tried Both before posting.
I did Tab over the Split line - Not Working its selecting the ceiling only to edit boundary Sad
I did filter it. Again i was not able to edit the split face profile - Not Working its selecting the ceiling only to edit boundary even after filterin n isolating it Sad
I was doing separate celings only till i read this work around to do things fast for client presentations where i have to quickly change patterns in the celing n give cost implications side by side.
Thanks .
Thu, Feb 18, 2010 at 6:07:10 AM | Modifying Split Face
Bhavani
Bhavani Avatar
It seems to work NOW!... i don know wht was the problem with that particular ceiling model!!! thanks a tonne guys Smile
Split face for multi colored wall
Wed, Oct 7, 2020 at 3:18:11 PM
SPLIT FACE BLOCK
Tue, Jul 18, 2006 at 10:41:24 AM
Split face on floor?
Wed, Nov 18, 2015 at 1:16:28 PM
Edit Split Face on Ceiling
Mon, Jan 25, 2010 at 4:42:26 PM
Modifying Slab deletes split faces
Thu, Mar 3, 2016 at 3:04:39 PM
Page generation time: 1.1355
