51 Users Online (49 Members):
Forums >> Revit Systems >> Technical Support >> converting dwg detail
i'm using mep 2010. i saw a good tutorial on how to convert a dwg detail into a revit detail. then save it into the library. but now i can't remember where i saw it. any ideas where to find it. i think it was part of a longer class. and at the time i didn't need it. now i'm starting to import alot of details. and they all have to be changed at least some. but then i will need to figure out how to make them light weight revit details, that can be grabbed for future projects. i'm finally getting some projects out of our office with revit. this will help speed up the next one.
Try to learn at least one new thing every day |
Here is what I recommend - no tracing involved - ALWAYS DO THIS IN A JUNK PROJECT FILE For CAD files you want to import into a drafting detail to clean up, you should do some prep work in CAD. But even before that, start a new REVIT project to use for your CAD cleaup that has your text and dimension styles as well as linetypes. The following assumes you have only three line styles in your REVIT file... Light - Medium - Heavy so adjust this process as appropriate. In CAD - Flaten 3D
- Explode all blocks and xref's
- Delete all hatches, polylines dimensions and leaders.
- WBlock to a new file only what you want.
In Revit - Create a drafting detail of correct scale
- Import your CAD detail from the new file
- Explode the CAD file (THIS IS A VERY BAD THING TO DO IN YOUR PROJECT FILE - THAT IS WHY WE DO IT IN A TEMPORARY FILE)
- Now - CAD lines are now new Revit linestyles named according to their layers.
- GOTO VG and turn off everything then turn back on the main line category and thin lines.
- Nothing should be visible.
- Goto Settings/Line styles - expand the lines category and repeat the following:
- Start with your heaviest line style in the CAD file. Find that linestyle (assuming A-DTL-Heavy) and delete that sub-category from your linestyles.
- All those lines will now be Thin Lines and will be visible
- Select them all from your detail window and change them to your Revit Heavy Lines and they will disappear.
- Repeat 8 - 10 above until you have converted all and your finished with thin lines.
- Convert all your text and clean that up.
- Add leaders to text notes
- Add dimensions
- Add filled regions.
- Click on File/Save to Library/Save Views and Pick your Details that you have cleaned up to save into your library.
- You can also transfer these views directly into your project.
thank you, i could remember parts of the tutorial that i saw, but not all of it. this will help alot.
I wrote this a year or two ago. Looking at it now, I would revise it. Since we are cleaning up in a junk file, no need to delete the linetyps. Justcross the wholeview then filter for a specific CAD linetype like A-DETL-HEAVY then change those toRevit HEAVY lines ... repeat the process until you have no CAD linetypes left.
by the way, i tried this out and it worked great. thank you
I'm a little late to the party here but something that I found useful was to use Laytrans in CAD to covert your exg layers
to the linestyles you want in Revit. Then when you do the explode you won't have to switch them over.
Converting to DWG file type. |
Fri, Apr 2, 2004 at 12:01:13 PM
converting sheets to dwg. |
Fri, Jun 25, 2004 at 11:02:17 AM
Converting DWG materials to Revit Materials |
Thu, Sep 13, 2012 at 3:50:29 AM
Import DWG into Detail Plan |
Wed, Mar 20, 2013 at 8:55:42 AM
Converting "Solidworks" files to Revit (or Autocad) format |
Fri, Mar 20, 2015 at 7:36:17 AM
Members: | 2030889 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
