57 Users Online (56 Members):
Forums >> Revit Structure >> Technical Support >> beams not snapping to beam/column
25 Posts No Rating |
When I model a beam to column or beam to beam for some reason it will not snap to the existing member. It acts as if there is no member there to frame into. Therefore it will not show the proper cut back in plan. I have started a new project to see if it happens there also. It doesn't, so I must have unknowingly changed something somewhere. anyone have any suggestions?
![](https://ci6.googleusercontent.com/proxy/KRnLbkX-hpqUHxK_ZTtWofWmS__jEx4Cbab_kYXcMqSsyTAi7DoEs3GNXPckBI6B7c9roTk7bfqgrf5841GtS3jIkBthAImpS4fqTSvL5c2hbdOvi496IgsAK6lUkoCAkY7TOr9BPiLwOPM577B6KuS8uEb-ZExUl44h-nnloL3VT2OcytdMNxRojyFuZr3gD8x6uqRDSI5Zp4I=s0-d-e1-ft#https://docs.google.com/uc?export=download&id=0By2tt3u4fCIpMWNBMkFtV1FoMDA&revid=0By2tt3u4fCIpMG40YUdVOTBlbGFCQzJ0U2V0N3FJMWVudlZrPQ)
Hey Shatcher, Here some ideas to go through/play around with: when you go to "Structural Settings" is the "Symbolic Cutback Distance" 3/32" or just greater than 0". When your modeling the beams is the "Placement Plane" set to the right level ex: modeling on Level 2 but the Plane is set to Level 3. Have you tried modeling in 3D vs 2D plan views and seeing if they snap that way. Are the beams your snapping to modeled correctly ex: 2'-0" Start Level Offset vs. 2'-0" z-Direction Offset Value. Hope this helps.
Aligning top of column to top of beams that are set out by bottom of steel |
Thu, Dec 12, 2013 at 12:35:41 PM
add beams conceptual mass |
Tue, Oct 15, 2013 at 7:52:39 AM
Concrete Beams not extending to Column C/L |
Wed, Jan 28, 2009 at 8:26:37 AM
Automatic extension of Beam |
Tue, Jan 24, 2012 at 3:24:46 AM
How do you align top of beam with top of column? |
Wed, Feb 11, 2009 at 8:19:29 AM
Members: | 2022335 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
