135 Users Online (134 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> topo lines under trees
Mon, Feb 15, 2010 at 8:20:37 PM | topo lines under trees
nklank
Is there a way to hide the topo lines underneath trees and other vegetation families in site plans other than taking the finished pdf into illustrator?
 Thanks
Nick
Tue, Feb 16, 2010 at 5:27:19 AM | topo lines under trees
4 Stars: 203 Votes
"Topo Lines" - are you talking about this topo lines?
Edited on: Tue, Feb 16, 2010 at 5:51:40 AM
Tue, Feb 16, 2010 at 5:49:11 AM | topo lines under trees
Kardiff
5 Stars: 3 Votes
Typhoo i think he means that planting are transparent on plan of that the topo lines cut through them
 My only suggestion is to edit your tree and plant family and place a tree shaped profile above it, and have it hidden in certain views (like how the furniture families tend to work so they appear white on plan even with a legend)
- Just trying to help out while I wait in the office for my renders to complete
www.danrossiter.co.uk
Tue, Feb 16, 2010 at 5:52:42 AM | topo lines under trees
Kardiff
5 Stars: 3 Votes
here, by editing my tree and putting a masking reigon at 'reference plane:top'I have made a simple cover for my trees, if you put more detail in, you can get the desired effect you're after
Wed, Mar 3, 2010 at 12:41:32 AM | topo lines under trees
nklank
I finally got around to trying to do this but when i tried to add the new level, it kept saying that it was invisible in that view and then it said it was visible in the visibility/overrides window.
Wed, Mar 3, 2010 at 3:57:28 AM | topo lines under trees
Kardiff
5 Stars: 3 Votes
you dont make a new level
select your tree, press edit
in the family files just draw a mask reigon over your tree and make sure it's reference is reference:top
Topo Lines part 2
Tue, Feb 28, 2012 at 10:05:01 PM
Some trees not casting shadows
Thu, Oct 16, 2014 at 10:55:22 AM
Drawing lines on 3D topo
Thu, Sep 22, 2011 at 9:29:47 AM
2D trees - Elevations
Wed, Oct 10, 2012 at 4:00:17 AM
Revit 2017 - Topography contour lines visibility
Wed, May 5, 2021 at 1:55:53 PM
Page generation time: 0.8780
