70 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> How to swicth between levels with a linked revit file
Mon, Feb 15, 2010 at 2:13:00 PM | How to swicth between levels with a linked revit file
Dthon
I currently have a file from an architect showing a 3rd and 6th floor...however when i link it into a new systems template to create our office central...it only lets me see the third floor.
How do i change it so my floor plans 1 & 2 coorespond to the sixth floor of the linked file instead of the third?
 p.s. I tried to change the view range, but it does not give me the optiion to match the linked file's levels, if so i don't know how to do it...any help would be appreciated.
Mon, Feb 15, 2010 at 2:55:19 PM | How to swicth between levels with a linked revit file
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Use By Linked View-And use a linked view of the appropriate level....
Regards,
Chris.
Mon, Feb 15, 2010 at 3:29:11 PM | How to swicth between levels with a linked revit file
Did you copy  / monitor the linked file's levels so that you would have them in your project?
Thu, Feb 18, 2010 at 7:43:40 AM | How to swicth between levels with a linked revit file
Dthon
i got it to work, thank you...think when i linked the revit file to my project it still brought in the sixth floor with the sixth floor level attributes...it just called the level levl 2 instead of importing the levls name...(not sure why what or how )
I tried at one point the copy/ monitor but i don't know if it worked or not as i've never used it before. I will also try the By-linked view-method as well Mr. Spot.
Thanks to both!
Cannot turn off levels in linked file
Mon, Jul 22, 2013 at 8:21:15 AM
Multiple or repeat levels in linked file
Sat, Aug 22, 2009 at 4:49:19 AM
Levels in linked files
Tue, May 24, 2016 at 9:40:39 AM
getting the levels and elevation from linked file
Sat, May 14, 2016 at 5:25:07 PM
Level-Head on linked Revit-file visible... puzzler.
Wed, May 11, 2011 at 8:29:35 AM
Page generation time: 2.5250
