90 Users Online (88 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Door family construction
Mon, Feb 15, 2010 at 4:58:38 AM | Door family construction
nirim
5 Stars: 12 Votes
Hi there
Need help in editing door family. I am attaching two images to show my problem. The first one showing the sweep profile that I want to extend and the second image show the error message that I receive when I try to finish the sweep profile editing process. I am using REVIT 2010
Regards,
Nirim
Mon, Feb 15, 2010 at 5:02:31 AM | Door family construction
4 Stars: 203 Votes
So, pick in the "Remove Constrains" and draw the profile, BTW lock that padlock....
Mon, Feb 15, 2010 at 6:07:13 AM | Door family construction
nirim
5 Stars: 12 Votes
Thanks for that but I don’t think it is that simple. I attached the family file, can you look at it and see if you can edit the left void sweep on the exterior side?
nirim
Mon, Feb 15, 2010 at 6:33:04 AM | Door family construction
4 Stars: 203 Votes
Here you have, the "Voids" are OUT of the panel that''s why they don't cut...
Mon, Feb 15, 2010 at 7:11:12 AM | Door family construction
nirim
5 Stars: 12 Votes
You door look good but I think it is not right, look at the 3D model and you will see the problem.
Nirim
Mon, Feb 15, 2010 at 7:12:12 AM | Door family construction
nirim
5 Stars: 12 Votes
Ooops
You door and not you door
nirim
Mon, Feb 15, 2010 at 7:23:02 AM | Door family construction
4 Stars: 203 Votes
That's wierd, i just "touch" the voids....
Mon, Feb 15, 2010 at 7:37:10 AM | Door family construction
nirim
5 Stars: 12 Votes
Meaning what?
(Sorry for not understand)
nirim
Mon, Feb 15, 2010 at 7:49:10 AM | Door family construction
4 Stars: 203 Votes
Forget.... the door is ok now?
Mon, Feb 15, 2010 at 8:01:49 AM | Door family construction
nirim
5 Stars: 12 Votes
I am afraid not the door is offset from the door frame.
nirim
Mon, Feb 15, 2010 at 8:51:48 AM | Door family construction
4 Stars: 203 Votes
Here we go again...
Mon, Feb 15, 2010 at 9:12:05 AM | Door family construction
nirim
5 Stars: 12 Votes
Typhoon that nice, the door is correct but I stile don’t understand what was wrong with it . Can you elaborate on that to recap the Q&A exchange?
Thanks
nirim
Mon, Feb 15, 2010 at 9:31:28 AM | Door family construction
#13
4 Stars: 203 Votes
the "Void" was outside the panel, then when align the void with the panel and i click "Remove the Constrains" it loose some constrains, then was necessary to align again some parts of the door with the ref. planes.
Mon, Feb 15, 2010 at 10:14:22 AM | Door family construction
#14
nirim
5 Stars: 12 Votes
Many thanks Typfoon.
nirim
Door Family Parameters
Thu, Feb 24, 2011 at 6:53:10 PM
Help - New door family error
Tue, Jan 15, 2008 at 12:34:05 PM
Door family - opening covers door leaf
Fri, Sep 30, 2016 at 4:36:46 AM
Help,what's wrong with my door family
Thu, Dec 30, 2010 at 8:06:56 AM
need help with my first door family. two issues...
Tue, Jun 5, 2007 at 7:47:51 AM
Page generation time: 1.0587
