33 Users Online (32 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> AREA SCHEDULE INCLUDING WALLS
Mon, Sep 12, 2005 at 10:36:44 PM | AREA SCHEDULE INCLUDING WALLS
Sparrow
I AM TRYING TO CREATE A SCHEDULE OF AREAS FOR THE WHOLE SITE, INCLUDING OUTDOOR AREAS, THAT LOOKS LIKE THE ONE ATTACHED. PROBLEM: HOW DO YOU TALLY THE AREA THAT THE WALLS TAKE UP? AND HOW DO I GET THE SCHEDULE FORMATTED LIKE THIS, WITH A SUBTOTAL FOR COVERED PLAY AREA?
Tue, Sep 13, 2005 at 9:50:03 AM | RE: AREA SCHEDULE INCLUDING WALLS
TomDorner
4.5 Stars: 25 Votes
I would use an area plan or plans. Revit comes with two area plan types defined. Gross and Rentable. In area plans these two types have rules that apply to them and you can have Revit automatically adjust your area line location based on these rules. Gross for instance places the area line at the exterior of the wall. Rentable adjusts the line locations based on BOMA standards. You can define your own are type plan in Revit. Doing so will result in a plan you simply have to place area lines in as the rules will no longer apply that are built-in to Revit/ Be sure to uncheck the apply rules box when placing area lines in these plans. To schedule like you want you may have to add a parameter (database field) to your schedule that you can sort and group on. Since Revit is a database it sorts and groups similar to other database applications. There are limits on formatting though and if you can live with these you can most likely accomplish what you want 100% inside of Revit. HTH Tom
Wall schedule does not show wall area for some walls - Revit Acrh 2012
Wed, Dec 12, 2012 at 12:33:45 PM
How to add wall area in schedule per wall
Thu, Nov 19, 2009 at 1:10:27 PM
Area Plan does not match Area from Materia/l Area
Tue, Feb 13, 2018 at 7:50:03 AM
Wall Area Schedule
Mon, Sep 19, 2011 at 3:44:22 PM
Area Schedule
Sat, Feb 26, 2005 at 10:39:29 AM
Page generation time: 1.1204
