33 Users Online (32 Members):
Forums >> Revit Building >> Technical Support >> Mullion offset from exterior glazing
8 Posts No Rating |
I'm having trouble attaching a mullion border to an exterior curtain wall, when I choose to insert the mullion on the "entire grid line" of the glazing, this grid line is an arbitrary line offset from the middle of the glass placing the mullion offset from the glass showing the glass as hanging off of the mullion. Any ideas? Thanks, -P
![5 Stars: 3 Votes](/images/stars_5.gif) |
could you attach an image im having trouble visualising your problem from your description thanks
- Just trying to help out while I wait in the office for my renders to complete www.danrossiter.co.uk |
8 Posts No Rating |
Surely, this is a picture of the bottom corner of the problem:
Being the weekend I dont have access to revit to have a play, but my only suggestion is to go into element properties and select border mullions in the grid pattern options and see if that stops your problem as opposed to manually placing it Either that or edit the mullion family and offset the profile off the reference line to the place you want it as save it as a speretate file
"Either that or edit the mullion family and offset the profile off the reference line to the place you want it as save it as a speretate file" - Do that Pdalt23 like Kardiff said....
8 Posts No Rating |
That worked perfectly. Thanks
Rendering Exterior Glazing |
Mon, Feb 20, 2012 at 2:45:05 PM
Sloped Glazing and Corner Mullion? |
Sun, Jan 11, 2009 at 9:51:39 AM
Glazing in curtain walls |
Thu, Dec 10, 2015 at 6:50:44 AM
Curtain Wall exterior align with building exterior |
Fri, Apr 24, 2009 at 7:15:32 AM
horizontal mullions |
Thu, Nov 16, 2006 at 11:02:46 AM
Members: | 2022388 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
